...::: NIEZBĘDNIK TECHNICZNY :::...
nokerman
ostatni mohikanin
Pomóg³: 21 razy
Do³±czy³: 22 Mar 2004
Sk±d: PuÅ‚awy
Wys³any: 2006-03-31, 06:40   Ustawienie rozrzÄ…du E36 318tds
Special tools
  • Flywheel timing pin - BMW No.11 2 300.
  • Timing chain tensioner locking pins - BMW No.11 3 340.
  • Camshaft alignment tool - BMW No.11 3 320.
  • Timing chain compressor tool - BMW No.11 3 360.
  • Injection pump sprocket puller - BMW No.13 5 120.
General precautions
  • Disconnect battery earth lead.
  • Remove glow plugs to ease turning engine.
  • Turn engine in normal direction of rotation (unless otherwise stated).
  • Observe tightening torques.
  • If fitted: Mark position of crankshaft position (CKP) sensor before removal.
  • Do NOT turn crankshaft via camshaft or other sprockets.
  • Do NOT turn crankshaft or camshaft with timing chain removed.
  • Check diesel injection pump timing after resetting valve timing.
Valve timing procedures
  • Engine at TDC on No.1 cylinder [1]11666.
  • Insert flywheel timing pin [1]11666. Tool No.11 2 300.
  • 4 cylinders: Align injection pump sprocket timing mark 4 with timing chain bright link [2]11666.
  • 6 cylinders: Align injection pump sprocket timing mark 6 with timing chain bright link [2]11666.
  • Align crankshaft sprocket timing mark with bright link [3]11666.
  • Install camshaft alignment tool [4]11666. Tool No.11 3 320.
  • Compress timing chain [5]11666. Use tool No.11 3 360.
  • Insert locking pins in tensioner [6]11666. Tool No.11 3 340.
  • Remove injection pump sprocket [7]11666. Use tool No.13 5 120.
  • Tighten injection pump sprocket nut to 50 Nm [8]11666.
  • Tighten crankshaft damper bolts to 22 Nm [9]11666.
  • [A]11666: 80 links. [B]11666: 74 links.
No.:13
nokerman
ostatni mohikanin
Pomóg³: 21 razy
Sk±d: PuÅ‚awy
Wys³any: 2006-04-11, 12:30   Ustawienie RozrzÄ…du E30 318i
Special Tools
  • Flywheel timing pin - BMW No.11.2.300.
  • Tension gauge - BMW No.11.2.080.
  • Camshaft setting tool - BMW No.11.3.190.
  • Temperature sensor - BMW No.11.5.060.
Special Precautions
  • DO NOT turn crankshaft or camshaft when timing belt removed.
  • Remove spark plugs to ease turning engine.
  • DO NOT turn engine via camshaft or other sprockets.
  • Observe all tightening torques.
Removal
  • Drain coolant.
  • Remove:
      Cooling fan and cowling.
      Radiator.
      Auxiliary drive belt(s).
      Water pump pulley.
      Distributor.
      Top hose and thermostat housing.
      Engine speed (RPM) sensor.
      Cylinder head cover.
  • Turn crankshaft to TDC on No.1 cylinder.
  • Insert flywheel timing pin [1]. Tool No.11.2.300.
  • Fit setting tool to camshaft [4]. Tool No.11.3.190.
  • Remove:
      Crankshaft pulley.
      Timing belt upper cover [2].
      Timing belt lower cover [3].
  • Slacken camshaft sprocket bolt.
  • Slacken tensioner bolt to release tension on belt.
  • Remove timing belt.
Installation
NOTE: DO NOT refit used belt.
  • Ensure flywheel timing pin located correctly [1]. Tool No.11.2.300.
  • Ensure setting tool located correctly on camshaft [4]. Tool No.11.3.190.
  • Ensure camshaft sprocket can just be turned by hand and turn clockwise against stop.
  • Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets on nontensioned side.
  • Attach tension gauge to belt at \-/. Zero tension gauge.
  • Turn tensioner pulley anti-clockwise until tension gauge indicates 45 units.
  • Tighten tensioner bolt. Tightening torque: 22 Nm.
  • Tighten camshaft sprocket bolt. Tightening torque: 63 Nm.
  • Remove:
      Tension gauge.
      Camshaft setting tool.
      Flywheel timing pin.
  • Turn crankshaft two turns clockwise.
  • Install:
      Flywheel timing pin [1].
      Camshaft setting tool [4].
  • Attach tension gauge to belt at .
  • Check cylinder head temperature above coolant outlet. Use temperature sensor No.11.5.060.
  • Slacken tensioner bolt. Turn tensioner pulley anti-clockwise until tension gauge indicates 45 units.
  • Turn tensioner pulley slowly clockwise until tension gauge indicates belt tension as follows:
      Cylinder head temp. Tension
      20°C ----------------32 units
      25°C ----------------33 units
      30°C ----------------34 units
      35°C ----------------35 units
      40°C ----------------36 units
      45°C ----------------38 units
      50°C ----------------39 units
  • Tighten tensioner bolt to 22 Nm.
  • Tighten camshaft sprocket bolt to 63 Nm.
  • Install components in reverse order of removal.
  • Fit crankshaft pulley. Ensure dowel pin located correctly. Tighten bolts to 23 Nm.
  • Refill cooling system.
No.:14
nokerman
ostatni mohikanin
Pomóg³: 21 razy
Sk±d: PuÅ‚awy
Wys³any: 2006-04-12, 07:09   Ustawienie RozrzÄ…du E32 735i
Special tools
  • None required.
General precautions
  • Engine at TDC on No.1 cylinder [1]11656.
  • Camshaft sprocket threaded holes aligned vertically [2]11656.
  • Camshaft sprocket dowel pin position [3]11656.
  • Remove tensioner plug [4]11656.
    NOTE: Plug [4]11656tensioned by strong spring.
  • Remove camshaft sprocket.
No.:15
nokerman
ostatni mohikanin
Pomóg³: 21 razy
Sk±d: PuÅ‚awy
Wys³any: 2007-01-12, 09:36   Kody Wyposażenia Vin Decoder
Kody Wyposażenia BMW
Póki co zdołałem zgromadzić tyle kodów:
201 3 FAHRPROGRAMME F.4-GANG-AUTOM 3programy AUT
202 STEPTRONIC Skrzynia Steptronic
209 LIMITED SLIP DIFFERENTIAL (25%) Szpera 25%
210 DYNAMIC STABILITY CONTROL (DSC) Układ stabilizacji jazdy DSC
213 HILL DESCENT CONTROL (HDC) - Kontrola zjeżdżania ze wzniesienia
214 AUTOMATIC STABILITY CONTROL+TRACTION (ASC) Układ stabilizacji jazdy ASC
215 POWER STEERING,DEPENDING ON ENGINE SPEED wspomaganie
219 SPORT LEATHER STEERING WHEEL Sportowa skórzana kierownica
227 SP/SUSPENSION W SELF-LEVELING SUSPENSION
240 LEATHER STEERING WHEEL skórzana kierownica
243 AIRBAG FOR FRONT PASSENGER poduszka kierowcy i pasażera
246 STEERING COLUMN ADJUSTMENT MECHANICAL regulacja kolumny kierownicy
255 SPORTS LEATHER STEERING WHEEL sportowa skórzana kierownica
270 WIDER TYRES
286 BMW LM RAD/BMW STYLING alufelgi
288 LT/ALY WHEELS alufelgi
291 LT/ALY WHEELS /CROSS-SPOKE /2-PRT alufelgi
296 LT/ALY WHEELS/CLASSIC alufelgi
300 ZENTRALVERRIEGELUNG ELEKTRISCH centralny zamek
301 DIEBSTAHLWARNANLAGE MIT ZV Alarm antywłaniowy z centralnym zamkiem
302 ALARM SYSTEM System alarmowy
303 INNENRAUMSCHUTZ/NEIGUNGSALARMG Alarm ruchu wewnatrz pojazdu i w trakcie podnoszenia auta
311 ELEKTRISCHER BEIFAHRERSPIEGEL elektryczne lusterko po stronie pasażera
314 HEATED WINDSCREEN WASHER NOZZLES podgrzewane lusterka i dysze spryskiwaczy
320 MODEL DESIGNATION, DELETION bez oznaczenia modelu
324 FRONT-UND HECKSPOILER przedni i tylni spoiler
331 SPORTPAKET
339 SATIN CHROME Czarne listwy polerowane
340 PROTECTOR STRIPES IN BLACK
350 WAERMESCHUTZGLAS GRUEN, RUNDUM szyby w zielonym odcieniu
351 WAERMESCHUTZGLAS BRAUN, RUNDUM szyby w brÄ…zowym odcieniu
354 GREEN STRIPE WINDSCREEN zielony pasek na szybie przedniej
386 ROOF RAIL relingi dachowe (w touringu)
400 SLIDING SUNROOF MANUAL szyberdach manualny
401 SLIDING/VENT ROOF, ELECTRIC szyberdach elektryczny
403 GLAS ROOF, ELECTRIC szklany szyberdach elektryczny
410 WINDOW LIFTS, ELECTRIC AT FRONT elektryczne szyby z przodu
411 WINDOW LIFTS, ELECTRIC elektryczne szyby (wszystkie)
413 LUGGAGE COMPARTMENT NET dzielona kanapa
415 SUNBLIND FOR REAR WINDOW Roleta tylnej szyby
417 SUNBLINDS FOR REAR SIDE WINDOWS, MECH Rolety tylnych bocznych szyb
423 FLOOR MATS, VELOUR welurowe dywaniki
428 WARNING TRIANGLE trójkąt ostrzegawczy + apteczka (pakiet)
431 INTERIOR RR VW MIRROR W AUT ANTI-DAZZLE
438 WOOD TRIM Drewniane wykończenia
440 NON-SMOKER PACKAGE Pakiet dla niepalÄ…cych
441 SMOKERS PACKAGE Pakiet dla palÄ…cych
459 SEAT ADJUSTM., ELECTR. W MEMORY F DRIVER Elektryczne siedzenie kierowcy z pamięcia
464 SKIBAG torba na narty
465 THROUGH-LOAD SYSTEM Dzielona kanapa
469 CHILD SEATS IN REAR, INTEGRATED Zintegrowany fotelik dziecięcy (tzw. ISOFIX)
473 ARMREST, FRONT Podłokietnik z przodu
481 SPORT SEATS F DRIVER/FRONT PASSENGER sportowe siedzenia
488 LUMBAR SUPPORT DRIVER/FRONT PASSENGER - regulowane podparcie lędźwi kierowca/pasażer
494 SEAT HEATING F DRIVER/FRONT PASSENGER grzane siedzenia
498 HEADRESTS IN REAR, MECHANIC. ADJUSTABLE regulowane zagłówki
499 HEADRESTS IN REAR, ELECTRIC. ADJUSTABLE - zagłówki z tyłu elektrycznie regulowane
500 HEADLIGHT WASHER SYS/INTENSIVE CLEANING Spryskiwacze świateł z intensywnym myciem
502 HEADLIGHT WASHER SYSTEM spryskiwacze reflektorów
508 PARK DISTANCE CONTROL (PDC) Asystent parkowania
510 HEADLIGHT BEAM-THROW CONTR. F LOW BEAM regulowane światła przednie
520 FOGLIGHTS halogeny
521 RAIN SENSOR Sensor deszczu
522 XENON LIGHT Światła ksenonowe
529 MICRO FILTER mikrofiltr w układzie wentylacji
530 AIR CONDITIONING klima manualna
534 AUTOMATIC AIR CONDITIONING klima automatyczna
537 STANDLUFTUNG UND AUSSENTEMPERATURANZEIGE wentylacja postojowa i wyświetlacz temperatury zewnętrznej
540 CRUISE CONTROL tempomat
545 DREHZAHLMESSER,KM/H-TACHO,AN.U licznik w km
548 SPEEDOMETER WITH KILOMETER READING
550 ON-BOARD COMPUTER no comment )
553 BORDCOMPUTER IV
556 EXTERIOR TEMPERATURE DISPLAY Termometr zewnętrzny + zegarek cyfrowy
562 MAP READING LIGHT
564 INTERIOR LIGHT PACKAGE
570 STRONGER ELECTRICITY SUPPLY Bogatsza wiÄ…zka elektryczna
571 BOOSTED POWER SUPPLY Alternator o zwiększonej mocy
609 NAVIGATION SYSTEM PROFESSIONAL Nawigacja Profesjonal
629 CAR TELEPHONE (GSM) W CARD READER FRONT Telefon z przodu
640 CAR TELEPHONE PREPARATION Instalacja przygotowana do telefonu
645 RADIO CONTROL US
650 BMW Bavaria C
651 BMW Bavaria C Reverse radio
652 BMW BAVARIA C II
654 BMW BAVARIA C III radio
658 RADIO BMW BUSINESS CD RDS
660 BMW BAVARIA REVERSE RDS
661 BMW BAV. CASS. III
666 RADIO BMW BUSINESS CD
669 RADIO BMW BUSINESS RDS
672 CD CHANGER BMW FOR 6 CDS Zmieniarka płyt CDx6
676 HIFI LOUDSPEAKER SYSTEM System audio Hi-Fi
679 HECKSCHEIBENANTENNE Antena w tylnej szybie
680 MANUAL AERIAL antena wysówana ręcznie
681 DACHANTENNE antena w dachu
682 RADIOANTENNE AUTOMATISCH antena elektryczna
686 ANTENNENDIVERSITY
690 CASSETTE HOLDER pojemnik na kasety
694 PREPARATION FOR CD CHANGER Instalacja przygotowana do zmieniarki CD
704 M SPORT SUSPENSION Zawieszenie M Technic
708 M-SPORT LEATHER STEERING WHEEL II Skórzana kierownica M Technic II
710 M LEATHER STEERING WHEEL Skórzana kierownica M Pakiet
773 WOOD TRIM Drewniane wykończenie
799 E30 INDIVIDUALSERIE 92 seria indywidual 92r
801 GERMANY VERSION wersja niemiecka
806 3RD STOP LIGHT Dodatkowe światło stop
813 FRANCE VERSION Wersja francuska
818 MAIN BATTERY SWITCH Główny wyłącznik zasilania
845 ACOUSTIC BELT WARNING Dźwiękowy sygnał niezapiętych pasów
848 ENLARGED WIRING HARNESS rozszerzona instalacja elektryczna
850 ADD FUEL TANK FILLING FOR EXPORT zatankowany zbiornik paliwa do transportu
853 LANGUAGE VERSION ENGLISH Angielska wersja językowa
854 LANGUAGE VERSION FRENCH Francuska wersja językowa
860 LTRL TURN SIGNAL LIGHT FRT Kierunkowskazy z przodu i z boku
863 EUROPE/DEALER DIRECTORY
876 RADIO FREQUENCY 315 MHZ
879 GERMAN/OWNERS HANDBOOK/SERVICE BOOKLET Książki Serwisowa i użytkownika po niemiecku
900 APPR. VEH.IMMOBILIZAT. ACC. TO AZT/TUEV
915 BODY SKIN CONSERVATION, DELETION konserwacja lakieru
925 SHIPPING PROTECTION PACKAGE Ochrona transportowa
992 NUMBER PLATE ATTACHEMENT MANAGEMENT Tabliczka znamionowa
No.: 16
lokop e30 320i
Tylko honorowo.
Do³±czy³: 23 Mar 2004
Sk±d: Lubin-Haverhill
Wys³any: 2007-02-26, 23:47   Wyglad Å›wiecy.
Wyglad świecy prawde Ci powie
http://www.126fan.pl/www/swiece.htm
Zabejcowac wszystkich!
Piotr_1
Tempiciel sekund
Do³±czy³: 11 Sie 2005
Sk±d: Bydgoszcz
Wys³any: 2007-03-18, 15:40   Kalkulator prÄ™dkoÅ›ci obrotowych na km/h
http://www.unixnerd.demon.co.uk/revs.html
Przełożenia 325i, 325ix, 324td E30:
Gear ratio
1. 3.83
2. 2.20
3. 1.40
4. 1.0
5. 0.81
R. 3.46
Final ratio. 3.64
(mam nadzieję że są poprawne)
Umieszczajcie seryjne przełożenia innych popularnych modeli
E30 325ic 1987.........-.../
MrKrYH_e34
Do³±czy³: 24 Sie 2004
Sk±d: Turek- PoznaÅ„
Wys³any: 2007-04-03, 17:46   CHECK CONTROL WSZYSTKO
I STOPIEŃ:
BREMSFLUSSIGKEIT - poziom płynu hamulcowego osiągnął MIN
OELDRUCK MOTOR - za niskie ciśnienie oleju w silniku. Natychmiast wyłączyć silnik
KUHLWASSERTEMP - za wysoka temperatura płynu chłodzącego
HANDBREMSE LOSEN - zwolnić hamulec ręczny
KEIN BREMSLICHT - brak świateł hamowania (przepalone żarówki lub bezpiecznik)
BREMSLI. ELEKTRIK - brak świateł hamowania (stopiony bezpiecznik lub obwód)
NIVEAUREGELUNG - samochód przeciążony
SPEED LIMIT - informacja o przekroczeniu zaprogramowanej prędkości
Powyższe usterki są natychmiast sygnalizowane gongiem i pulsującymi znakami wskazującymi (rys - punkt 1). Usterki występujące jednocześnie są sygnalizowane kolejno. Informacje pozostają aż do usunięcia usterek i nie można ich wygasić przyciskiem check control (CC) (rys - punkt 2)
II STOPIEŃ:
GETRIEBEPROGRAMM - usterka w elektronicznym sterowaniu automatycznej skrzyni biegów
BREMSBELAGE - zużycie okładziny hamulców
WASCHWASSERSTAND - niski poziom płynu do spryskiwaczy
TUR OFFEN – drzwi otwarte
KOFFERRAUM OFFEN – bagażnik otwarty
1 BREMSLICHT - przepalona żarówka światła hamowania
ABBLENDLICHT - światło mijania (przepalona żarówka, uszkodzony bezpiecznik lub obwód)
STANDLICHT – przepalona żarówka Å›wiatÅ‚o postojowe (jak wyżej)
RUCKLICHT – Å›wiatÅ‚o cofania (jak wyżej)
NEBELLICHT VON - światła przeciwmgielne przód
NEBELLICHT HONT. - światła przeciwmgielne tył
KENNZEICHENLICHT - oświetlenie tablicy rejestracyjnej (jak wyżej)
ANHANGERLICHT - światła przyczepy (uszkodzony bezpiecznik lub obwód)
Informacje są wyświetlane, gdy kluczyk zapłonu jest w pozycji 2 (w pierwszej kolejności są wyświetlane informacje z priorytetu 1). Po zgaśnięciu napisu pozostają znaki wskazujące. Znak plus (rys - punkt 3) oznacza, że są jeszcze inne informacje, które należy wyświetlić naciskając przycisk CC.
Uwaga: Przyciskiem CC można wygasić informacje przed ich automatycznym wygaszaniem lub wyświetlić z pamięci informacje sygnalizowane znakami wskazującymi.
III STOPIEŃ:
OELSTAND MOTOR - poziom oleju w silniku osiÄ…gnÄ…Å‚ MIN
OEIST. LENKHILFE – pÅ‚yn wspomagania kierownicy
KUHLWASSERSTAND - niski poziom płynu chłodzącego
CHECK CONTROL - usterka w układzie elektronicznym
OELDRUCK SENSOR - czujnik oleju nie działa nie podłączony
SENSOR OELSTAND - uszkodzony czujnik poziomu oleju
LICHT AN? - włączone światła
Najważniejsza informacja jest wyświetlana po zakończeniu jazdy w pozycji O kluczyka zapłonu (w razie kilku informacji są one wyświetlane kolejno - informacje priorytetu 3 następują po informacjach priorytetu 2 i 1). Informacje można przywołać przyciskiem CC w ciągu 3 minut po zakończeniu jazdy - nawet po wyjęciu kluczyka zapłonu i zgaśnięciu wyświetlacza. Informacje są wyświetlane także przed jazdą, gdy kluczyk zapłonu jest w pozycji 2, ale po krótkim czasie lub po rozpoczęciu jazdy znikają teksty i nie świecą znaki wskazujące. Informacje są wyświetlane ponownie dopiero po obróceniu kluczyka zapłonu w pozycję 0.
Znak plus oznacza: Wyświetlić dalsze informacje naciskając przycisk CC.
Wskazówki ogólne:
Gdy pojawi się napis >> Betriebsanleitg << należy znaleźć wyjaśnienie w instrukcji obsługi pod nagłówkami Informacja / Postępowanie
Napis >> Betriebsanleitg << można wygasić przyciskiem CC.
Sprawdzanie wyświetlacza check control (tylko, gdy nie są wyświetlane informacje): Obrócić kluczyk zapłonu w pozycję 2 i nacisnąć przycisk CC. Musi pojawić się napis CHECK CONTROL OK.
BETRIEBSANLEITG – instrukcja obsÅ‚ugi
SajGoN
zakochany w E30
Do³±czy³: 08 Gru 2006
Sk±d: Å�ukówPL/PortsmouthUK
Wys³any: 2007-05-28, 19:00
W oznaczeniach silnikow jest troche do poprawki:
M10 (+1.6)
M20/B27 (Eta byla w E34? a poza tym to nie 8V a 12V)
M20 (+2.0)
M30 (12V +E34)
M40 (tutaj +E34 518i)
M42 (is w E34? czy to ta sama historia co M44 w E46 318i ?)
M42/? (nie bylo w E30 i E34 ale byl w E46)
M43 (1.8 SOHC-8v/L4 E36)
nie ma M44 1.8 DOHC-16V/L4 E36,E46
M50 2.0/2.5 DOHC-24v/L6 E34/E36
M50TU 2.0/2.5 DOHC-24v/L6 w/VANOS E34/E36
M52 (2.0 byl jeszcze w E46 i B28 byly w E38 i E39)
M60 (3.5)
M70 (M70 5.6??? z tego co wiem to M70 to 5.0 300KM i 5.4 326KM)
S14 (a 2.0/ wloska wersja 320is?)
S38 (3.6 i 3.8 ///M5 E34)
S50 (3.2 M3 Evo E36)
S52 3.2 (wersja USA)
S80 (bzdura w M5 E34 nie bylo silnika S80 tylko S38)
to tyle co od siebie. Poprawilem te dane z glowy bez sledzenia danych technicznych. Mozna by uzupelnic to w nowe silniki, ale to juz bym musial siegac do zrodel. W nawiasach napisalem to czego brakuje lub poprawki. Jak cos jest ze znakiem zapytania to znaczy ze nie wiem jak np: Eta w E34.
Jesli gdzies sie pomylilem to poprawcie mnie. Bo w temacie doklejonym o tak ambitym tytule nie powinno byc pomylek.
SPRZEDAM!
E36 328i anglik-tanio
Azev A 4x100 16" i 17"na sztuki
Skrzynia 6-tka z M3 3.2
Automat z E36 328i Coupe
kafarek
Master of desaster
Do³±czy³: 12 Maj 2005
Wys³any: 2007-06-13, 15:46
Wykaz bezpieczników E32 do 91 roku
nokerman
ostatni mohikanin
Pomóg³: 21 razy
Sk±d: PuÅ‚awy
Wys³any: 2007-07-02, 00:11
kod na Max Weapon - 154F4DFF87487/
kod na Max Ammo - D1F56484ZF13687S
kod na Unl Health - 666FGRSFSD666
kod na więcej żyć - JEDZUWAZNIEOK
mariusz szkocja
Wys³any: 2007-07-16, 20:47
siemka
http://www.rayd.co.uk/blo...plinks/BMWLinks
przejrzyj jak cos sie nadaje to zrob z tego uzytek
Piotr_1
Tempiciel sekund
Sk±d: Bydgoszcz
Wys³any: 2007-09-15, 16:26
Diagnozowanie sondy lambda w warsztacie:
http://www.moto-profil.pl...e_sondy_ntk.pdf
mariusz szkocja
Wys³any: 2007-10-13, 15:10
http://forum.beemka-klub....p=248292#248292 tu rzuc okiem pare kodow do kolekcji i jeszcze
200 -katalysator -entfall
362- vent rear windows , electic tylne szyby uchylane elektrycznie (coupe)
528 automatic air recirculation control(AUC)
674 HIFI loudspeaker system HARMAN KARDON
940 special request equipment
Ostatnio zmieniony przez mariusz szkocja 2007-10-13, 15:16, w ca³o¶ci zmieniany 1 raz
Pawel735
Do³±czy³: 19 Sty 2006
Sk±d: BiÅ‚goraj
Wys³any: 2007-10-13, 19:32
RealOEM z cenami w PLN - link podał ROBOCOP
http://www.mototec.pl/etk.php
Pomóg³: 46 razy
Do³±czy³: 03 Lip 2004
Sk±d: Walcz/Londyn
Wys³any: 2008-02-24, 23:14
opis i fotki wrona:
spoiler tyl:
[url=http://img225.images....th.jpg]Obrazek[/URL]
[url=http://img337.images....th.jpg]Obrazek[/URL]
[url=http://img219.images....th.jpg]Obrazek[/URL]
progi:
[url=http://img164.images....th.jpg]Obrazek[/URL]
[url=http://img229.images....th.jpg]Obrazek[/URL]
[url=http://img266.images....th.jpg]Obrazek[/URL]
[url=http://img231.images....th.jpg]Obrazek[/URL]
tylna dokładka zderzaka
[url=http://img118.images....th.jpg]Obrazek[/URL]
[url=http://img123.images....th.jpg]Obrazek[/URL]
[url=http://img127.images....th.jpg]Obrazek[/URL]
[url=http://img70.imagesh....th.jpg]Obrazek[/URL]
[url=http://img262.images....th.jpg]Obrazek[/URL]
[ Dodano: 10-10-2007, 23:17 ]
przednia dokładka zderzaka
[url=http://img240.images....th.jpg]Obrazek[/URL]
[url=http://img115.images....th.jpg]Obrazek[/URL]
[url=http://img222.images....th.jpg]Obrazek[/URL]
[url=http://img260.images....th.jpg]Obrazek[/URL]
[url=http://img186.images....th.jpg]Obrazek[/URL]
[url=http://img119.images....th.jpg]Obrazek[/URL]
i spakowane w lepszej rozdzialce na rapidzie:
http://rapidshare.com/fil...mtechI.rar.html
Bandit
Do³±czy³: 02 Lut 2008
Sk±d: Å�ódź
Wys³any: 2008-03-18, 01:24
Kolejna opcja:
S877A Deletion cross-over operation Brak obsługi krzyżowej
W związku z tym mam pytanie. Co ma samochód z tą opcją :?:
100% zgodności z VIN - dla mnie to duma, dla większości nieosiągalne
Szajbaa
Fan Marki
Pomóg³: 19 razy
Do³±czy³: 04 Mar 2008
Sk±d: warszawa
Wys³any: 2008-08-06, 16:54
czy tylko mi nie działa połowa linków czy moderatorzy juz zapomnieli o tym dziale ?
tel: 506-799-133
gg: 4995986(niewidoczny)
madcar
Do³±czy³: 22 Maj 2005
Sk±d: ToruÅ„
Wys³any: 2008-09-17, 14:14
poprawcie link do "systemy elektroniczne ECU"
http://www.atpelectronics.co.uk/Catalogue/bmw.htm
:wink:
www.dt-motorsport.com.pl
byl sobie e21 320 `79...
Pomóg³: 37 razy
Do³±czy³: 31 Sty 2005
Sk±d: Lubuskie - Cybinka
Wys³any: 2008-11-13, 19:57
Kompletne dane regulacyjne oraz opisy z fotami plus troszkę schematów oraz dane do sprawdzania czujników niestety po angielsku - sporo danych o Dieslu M21.
http://www.bmwtechinfo.co...n/index_cd3.htm
Marcin e30
obibok :)
Do³±czy³: 20 Cze 2004
Sk±d: Å�owicz
Wys³any: 2008-11-19, 10:16
to ja dodam jeszcze 4 kody których tu nie znalazłem:
260 - SIDE AIRBAG DRIVER/FRT PASSENGER - boczna poduszka powietrzna kierowcy / przednia pasażera - i to jest dziwne bo w samochodzie są też boczne dla pasażera
665 - RADIO BMW BUSINESS
811 - BELGIUM VERSION - wersja belgijska
877 - DELETION CROSS-OVER OPERATION
886 - DUTCH/OWNERS HANDBOOK/SERVICE BOOKLET - holenderskojęzyczna instrukcja użytkowania / książka serwisowa
Ostatnio zmieniony przez center 2008-12-14, 17:13, w ca³o¶ci zmieniany 2 razy
MARCIN DJ
Do³±czy³: 24 Cze 2008
Sk±d: PuÅ‚awy
Wys³any: 2008-11-21, 16:55   katalog z częściami - mam nadziejÄ™, że siÄ™ komuÅ› przyda
http://bmwfans.info/original/ :)
DjAquaz
Do³±czy³: 06 Gru 2008
Sk±d: Glasgow
Wys³any: 2008-12-24, 11:27   Książka "Kody Usterek" PDF
A z mojej strony mogę wam polecić książke w pdf dotyczącą usterek i kodów usterek do większości modeli samochodów w tym BMW
Kod:
http://rapidshare.com/files/176338629/Ksi____ka_Kody_usterek.pl.rar
Pozdro[/b]
[ Dodano: 2008-12-24, 12:07 ]
Świetna książka dla ludzi którzy chcą zrozumieć istote rzeczy elektronicznych i zasady ich działania
Kod:
http://rapidshare.com/files/176349142/Elektrotechnika_I_Elektronika_W_Pojazdach_Samochodowych.rar
Ostatnio zmieniony przez DjAquaz 2008-12-24, 11:28, w ca³o¶ci zmieniany 1 raz
Pomóg³: 97 razy
Do³±czy³: 14 Maj 2006
Wys³any: 2009-01-20, 18:24
DjAquaz napisa³/a:
http://rapidshare.de/file...._sam..rar.html
Poprawiony plik do kompletnej książki 85 mb!!
Pomóg³: 97 razy
Wys³any: 2009-01-23, 18:43
walker napisa³/a:
Panowie a co znaczy :?:
0305 Fernbedienung F.Zentralveriegelung
0832 Batterie im kofferraum
zdalnie sterowany centralny zamek i akumulator w bagażniku, ale to chyba nie jest miejsce na takie rzeczy....
morela
Do³±czy³: 22 Kwi 2009
Sk±d: InowrocÅ‚aw
Wys³any: 2009-04-22, 13:51
Skąd można sciągnać ETK??
Strona wygenerowana w 0,06 sekundy. Zapytañ do SQL: 16
